Dryer dve45m5500w vent blockage light on, vents clear
(Topic created: 06-05-2022 05:50 AM)
Members_5EGD2db
Washers and Dryers
Every time we run a load the vent blockage light comes on within 5 minutes of starting the load.
I run a vent blockage test and it comes back no blockage. I’ve checked the exhaust system from the lint trap all the way to the outside of the house. It’s all very clean. I’m thinking a sensor is bad but not sure.
Again while running a load it says there is a blockage but the vent blockage test says no blockade. Anyone have advice?
Samsung_Moderator
Washers and Dryers
Hi there! I can definitely understand your concern about the vent blockage light being on. Since you have verified the vents and duct work are clear of any clogs, at this time we would recommend service. There’s a couple options here we can take based on your warranty status.
If you’re in the one-year manufacturer’s warranty, please gather together the full model and serial number of your unit, and have ready your name, street address, 2 phone numbers (Best contact, alternative number), email, and place of purchase. Provide this information to an agent, in one of the following options below:
1.) Reach out to a Moderator directly, by selecting our name and the message option. When messaging please use a link to this thread in addition to the info above.
2.) Reach out to us on Facebook or Twitter. Please provide the same info as above, as well as the link to your thread.
3.) You can also contact 1-800-726-7864, if you’d like to speak with a live agent about this situation.
4.) Last, if you wish to speak with a live agent and don’t want to call in, you can reach out to our Live Chat team.
If you’re out of the one-year manufacturer’s warranty:
1. You can utilize this link to locate an authorized service center in your area to obtain estimates for repairs: http://www.Samsung.com/us/support/service/location or reach out to any local repair shop.
2. The other option, would be a replacement of the unit. Samsung.com offers amazing deals on different models that may be to your liking, check out those deals here: https://www.samsung.com/us/dryers/
1 Reply
Samsung_Moderator
Washers and Dryers
