Vicious88
- Mute
Thursday in
Washers and Dryers
I have a Samsung washer WA547ABP/XAA(I know old washer š)...for a few months when I'm doin laundry and have to utilize "warm" I'm only getting cold water. Now if i do a "Pure Cycle" or like "Sanitize" just to force hot water only to come out then it will. I just replaced my water inlet valve and still have the same issue. Hot water still runs out of the hot water hose so there's nothing wrong with my water tank and my hoses are NOT swapped. Everything is plugged correctly. However i was also told, it's possible something is wrong with the PCB. Can I get some help or do I just need to get a new washer?
1 Reply
meself
Black Hole
- Mute
Thursday in
Washers and Dryers
I think you found the issue being the board should just be a quick fix to replace try warranty repair
![](/skins/images/D58B14EE8BA77C7F81627A6C90A16C45/responsive_peak/images/icon_anonymous_message.png)
