VERY Loud in Rinse/Spin Cycle, New Problem, less than 4 years old
(Topic created: Friday)
BatmanAZ
Washers and Dryers
New onset of extremely loud rinse/spin cycle.
No knocking. No vibration. Just loud.
Measured at 96db. That's extremely loud.
Normal Samsung sound in rinse/spin is 73db.
Any ideas?
1 Reply
GaryB82
Galactic Samsung Care Ambassador
Washers and Dryers
It could be a number of things that could cause this to happen I would suggest contacting a certified repair center to have it checked out
https://www.samsung.com/us/support/service/locations/
If your Samsung washer is making a very loud noise during the spin cycle, it could be due to an unbalanced load, a broken drive pulley, or worn-out bearings or sealsHere's a breakdown of potential causes and solutions:
Possible Causes & Solutions:
    • Unbalanced Load:
      • Problem: A small or large load can cause the tub to become unbalanced, leading to a bumping or rattling sound.
      • Solution: Ensure laundry is evenly distributed, or add or remove items to achieve a more balanced load.
    • Broken Drive Pulley:
    • Problem: The drive pulley connects the motor to the washer tub, and if broken, the washer won't spin correctly.
    • Solution: Contact a professional dryer repair technician to replace the drive pulley.
  • Worn-Out Bearings or Seals:
  • Problem: Wear and tear can cause bearings and seals to fail, leading to loud noises and potential leaks.
  • Solution: Replacing the tub seal and bearing is a complex repair that may require disassembling most of the washer.
  • Shipping Bolts Not Removed:
  • Problem: If the shipping bolts (used to secure the washer during transport) are not removed, the washer may make a loud noise.
  • Solution: Ensure that the shipping bolts are removed.
  • Leveling Issues:
  • Problem: If the washing machine is not on a level surface, it can cause excessive noise and vibration.
  • Solution: Adjust the washing machine feet to level the appliance.
  • Other Issues:
  • Problem: In rare cases, the door seal can rub against the drum, causing unusual noises.
  • Solution: Inspect the door seal for wear and damage, and contact Samsung customer support if needed.
  • Problem: Weak shock absorbers can also cause a loud banging sound during the spin cycle.
  • Solution: Check the shock absorbers and consider replacing them if they are weak.
  • Problem: Overloading the drum is a common cause of a washer making noise, and it usually sounds like grinding.
  • Solution: Make sure you are not overloading the drum.
Troubleshooting Steps:
  • Check for an Unbalanced Load: Try redistributing the laundry or removing some items to see if the noise subsides.
  • Ensure Shipping Bolts are Removed: Double-check that the shipping bolts are removed.
  • Level the Washer: Make sure the washer is on a level surface and adjust the feet if necessary.
  • Inspect the Door Seal: Check the door seal for wear and damage.
  • Contact Samsung Support: If the problem persists, contact Samsung customer support for further assistance.
  • Consider Professional Repair: If the issue is related to worn-out bearings or seals, it's best to contact a qualified appliance repair technician.
If you've found my post to be helpful, Please like my Comments āœ“āœ“āœ“.
If my response resolved your issue, please press the Like and āœ“āœ“āœ“ to Accept as Solution button.
