Washing machine WW80T4040CX1AS Door Lock disengage sound
(Topic created: 11-11-2022 03:12 PM)
Zeyad_A
Washers and Dryers
Hello everyone,
I just bought a new Samsung washing machine and at the end of cycle when the door disengages, the door lock disengage sound clicks two or three times instead of just one time. I’m very worried if that is normal or is some component faulty ?
jtcluck1
Washers and Dryers
That is quite normal from my experience
1 Reply
jtcluck1
Washers and Dryers
