how to use self clean on Model WA50R5400AV, Samsung 5.0CuFt Top Load Washer with Super Speed
(Topic created: 01-17-2024 01:40 PM)
vinothkumarv
Washers and Dryers
I need help on how to use "self clean" on Model WA50R5400AV, Samsung 5.0CuFt Top Load Washer with Super Speed. I mean, should this option used with any sort of cleaning detergents or something and what is this for, when to use it and so on. Appreciate any help on this as I do not have the user manual.
Samsung_Moderator
Washers and Dryers
Hello there and welcome to our Samsung Community. It will be my pleasure to assist with your inquiry regarding the self-cleaning function of the washer.
To get started, let's answer "what is this for" -the self-cleaning feature is to prevent build-up of residue or odor causing bacteria and can absolutely assist with keeping your washer tub fresh and clean.
Secondly, the user manual I've provided here- https://downloadcenter.samsung.com/content/UM/202306/20230630150634868/DC68-04037H-03_IB_WA50R5400A_... advises Do not use or mix any other detergent or chemicals during the SELF CLEAN cycle.
Finally, we strongly recommend performing the self clean cycle at least once a month or
every 20 cycles. You can download a free e-copy of the manual here- https://www.samsung.com/us/support/downloads/?model=N0053978&modelCode=WA50R5400AV/US for further review as well and we hope you enjoy your washer.
Samsung_Moderator
Washers and Dryers
userG4Lsu529wc
Washers and Dryers
My washer makes a grinding noise during the spin cycle. What could be the problem, and what new part do I need to order to fix it? Model wa45t3200aw
