user0Q6QAUhVAT
- Mute
ā05-07-2022
09:00 AM
(Last edited
ā08-23-2023
05:01 PM
by
SamsungCaleb
) in
Hi, my smart tv has roku built in, but I can not find the roku menu, please help.
Solved! Go to Solution.
Faith4Hope
Comet
- Mute
ā05-15-2022 11:18 PM in
Projectors & Other TVs
There should be multiple ways to locate The Roku Channel:
You can set your "Source" to "TV" (default) if you'd like, but it's totally optional
ā
Press the "Mic" buttonā say "Open The Roku Channel" or "Open Roku Channel"āIt'll open within a few seconds
"Home"āscroll to the right of "Home" until you find it
"Home"ā"Search"āinput "Roku"
"Home"ā"Apps"ā"Search"āinput "Roku"
"Home"ā"Apps"ā"Settings"āscroll until you find it
With the other methods (excluding the voice command one), The Roku Channel app should come up & there should be a dark circle with the download symbol in it to show that it's installed. If it's not on Roku's tile, it's not installed, so you can install it. If it's already installed, select its tile to launch. For the voice command method, as it's opening & loading, the name & logo should appear on-screen until it's fully loaded & ready to use.
If you still can't find it, then you definitely will need to contact Samsung support or use an external Roku streaming device.
I really hope this helps! If it does, please consider giving a heart & marking this as a solution, thanks! Take care šš
ā
cubabori
- Mute
ā05-07-2022 09:16 AM in
Not the place to be asking at.
Faith4Hope
Comet
- Mute
ā
ā
![](/skins/images/C6D28B2BCD1D8A098D785FC1C2CFD78E/responsive_peak/images/icon_anonymous_message.png)
