- Mute
05-29-2020 01:19 PM in
4K, 8K and Other TVsI've deleted the original HBOGO app and downloaded the max app and there is still no sound on video. My tv still has sound on every other app and in the app but when I try to play a video there's nothing.
Solved! Go to Solution.
- Mute
07-15-2020 02:44 PM in
4K, 8K and Other TVsI don't know if this helps your situation but I solved the same problem. If you have a soundbar connected via digital audio cable HBO max doesn't support the audio output. Fortunately my TV and Samsung soundbar are both HDMI arc compatible so a 2 minute fix by connecting the HDMI worked
- Mute
05-30-2020 12:38 PM in
4K, 8K and Other TVsI'm sorry to hear that, is it everything you watch on the app? Also have you reached out to HBO support about this?
- Mute
- Mute
12-26-2020 04:51 PM in
4K, 8K and Other TVsI have a Samsung TV and Samsung sound bar, both new. HBO max volume is very low, need to turn the sound bar all the way up. My sound bar is connected by an optical cable. Should I switch to hdmi?
- Mute
01-15-2021 10:57 PM (Last edited 01-15-2021 11:07 PM ) in
4K, 8K and Other TVsI am also having this problem of extremely low audio volume on all my Samsung TVs which also have Samsung soundbars (none are new but also no older than 3 years) but mine are hooked up via HDMI ARC. It is very obvious on movies I've watched before elsewhere because there is almost no bass. I don't have this issue on any other apps downloaded to the TV, just HBO Max (didn't have this issue with HBO Go). I could never find a solution so I have started straming HBO Max from either Apple TV or a Fire Stick but would prefer streaming directly from my tv.
Did you ever find a solution to the problem?
- Mute
08-25-2020 07:53 PM in
4K, 8K and Other TVsI have this problem. No sound for HBO Max. Sound for everything else.
- Mute
09-26-2020 05:27 PM in
4K, 8K and Other TVs- Mark as New
- Mute
11-27-2020 12:25 AM in
- Mute
11-27-2020 05:12 PM in
4K, 8K and Other TVsIs there a soundbar connected to the television by any chance or are you using the television speakers?
- Mute
12-08-2020 10:18 AM in
4K, 8K and Other TVsI also have the same issue. Samsung 6 series TV. Occasionally the sound does work, so it is not a hardware or setup problem. Very frustrating. I have soud for everything else. I also have a Q6 and that always seems to work fine.
