- Mute
3 weeks ago (Last edited 3 weeks ago ) in
QLED and The Frame TVsI have a QN65 and my remote stopped working. If I remove the batteries and put them back in (fresh batteries), the first button I press works, but any button after that does not work and flashes red. This would mean that its paired to my TV if the first button I press works? I've tried resetting and re-pairing but it never actually re-pairs.. Not sure what else to do to fix it.
Solved! Go to Solution.
- Mute
2 weeks ago in
QLED and The Frame TVsSo what I did that ended up working is navigate via using my phone as a remote to the settings menu to re-pair the remote. This fixed the issue. I hope your phone is already paired to your tv...
- Mute
2 weeks ago in
QLED and The Frame TVsI have this exact problem! It started a couple of days ago, software update problem? I have to reset the tv by holding the power button and hard shutoff the device. I can use my phone as remote.
- Mute
2 weeks ago in
