- Mute
04-25-2024 12:54 AM in
QLED and The Frame TVsI saw a prompt on the TV to press the "Back button" and Play Button for 3 seconds, I did that and now when I press any button there's Bluetooth Icon with "Searching for device" under it. Every time I press a button, that pops up, I can't do anything on the screen. When I turn it on and off no change, The remote keeps blinking even when I try to charge it.
I spent way too much on this 4k smart TV and now it's basically Useless. SMH
Samsung - 55” Class S95B OLED 4K Smart Tizen TV
Solved! Go to Solution.
- Mute
04-25-2024 02:34 AM in
QLED and The Frame TVs- Mark as New
- Mute
- Mute
04-25-2024 02:36 AM in
- Mute
05-10-2024 08:49 AM in
QLED and The Frame TVsThe same thing happened with mine… I don’t know if it’s a true fix, but I got it to work. While it was searching, I waited for the “no devices found try again” prompt. After holding the buttons again I held the remote right next to the sensor on the TV. It started to try to connect instead of just searching. Mine did not connect but it said “unable to connect to device”. From there I was able to hit the back button and had full control of my remote.
