Samsung TV Plus channel guide not showing
(Topic created: 11-13-2023 06:09 PM)
parker512
Projectors & Other TVs
When I turn on Samsung TV plus I can only get Channel 1000 Movie Hub.  When I click down on the remote twice, the channel guide isn't showing.  How do I get the channel guide to show on the Samsung TV plus.  It works on all of my Samsung TV's except for my UA65AU9000WXZW.  Please help!
OoYORIoO
Sun
@parker512
Here's further information on obtaining Service for your Samsung Television:
Please contact Samsung Customer Care: 1-800-SAMSUNG
You can find support at Samsung's Website here:
https://www.samsung.com/us/support/contact/
Thank you for using the Samsung Member's Community. We appreciate your feedback. Thank you!
Lin Jiayi
Cosmic Ray
Your TV is not connected to the Internet, or the network signal is unstable, making it impossible to obtain channel guide data.
Your TV is not updated to the latest firmware version or has some system errors that prevent the channel guide from functioning properly.
Your TV is not set to the time and date correctly, or the correct region is not selected, resulting in mismatched channel guide information.
parker512
I checked all of this and its still not working.
Not applicable
@parker512
1. Press Settings on your Samsung Television Remote
2. Scroll down to "Broadcasting"
3. Tab over to "Auto Program"
4. Select Air/Cable as your preferred type
5. The Television will scan for New Channels and Samsung TV Plus Channels that are available to you based on your region (Ie: Canada, USA, or other country)
You can also try this:
2. Tab down to "Network"
3. Tab over to "Network"
4. Select Network Status" (See if your connected to your Network)
Also try Disconnecting from your Network. Perform a rescan of your Television Channels while being Disconnected from your Network.
***The Network Guide WILL WORK without a Network Connection***
parker512
I tried all this and its still not working.
OoYORIoO
Sun
@parker512 I'm sorry to hear that you were unable to resolve the issues your experiencing with your Samsung Television. I'd like to suggest another potential solution to your issue.
1. On your Samsung Television Remote
2. Press "Settings"
3. Tab down to "Support"
4. Select "Self Diagnosis"
5. Press the "OK" Key
6. Select "Reset Smart Hub"
Thank you for using the Samsung Member's Community. We appreciate your question and feedback about your Samsung Televison. Thank you!
OoYORIoO
Sun
@parker512
1. Manually assign an IP address to your Samsung TV
2. Manually Assign you DNS Server to 8.8.8.8
3. Check the Channel Guide for your Samsung TV Plus!
OoYORIoO
Sun
@parker512 Did you find my answers to your question to be satisfactoy? If I helped you. Please tap on the answer that I have provided as an "Acceptable Solution" Thank you!
parker512
Sorry..still not working.
OoYORIoO
Sun
@parker512
