Bluetooth headphones audio distortion issue A54
(Topic created: 12-21-2023 08:44 AM)
Pensation
A Series & Other Mobile
I'm not sure if it's just my phone, but after the most recent update, my Bluetooth headphones are having some very bad audio distortion.
I've connected the same headphones to other devices and it works perfectly fine!
The phone I'm currently using is the A54
Is there any fix to this issue?
userHOsVF4Uy1u
Pensation
It didn't work
Pensation
So far it's been happening with both YouTube and Google Chrome.
The distortion sounds very chopped up
userHOsVF4Uy1u
JenA13
Ok! YES! Thank you Constellation! It worked 🙂 The only thing you need to know is, in the settings, then "about phone" you need to tap the "build number" 7 times to get to developer mode. Yes, then turn on the A2DP as posted above. THIS just made my day!
steppinstl
Ohmg!!!!!!! Thank you this worked!!!!
asperand
same issue, no solution works
could samsung give us a fix?
a1star
I have the same problem thought it was weird but found the same bluetooth earphones that did not work with A54 worked with my older samsung phones just fine. It affected some of my bluetooth earphones but not all of them. I even went as far as to buy a new pair, just got them today and they did not work. 😞
