Flashlight does not work when using the camera flash notifications
(Topic created: 07-23-2024 12:36 AM)
RobertMartinez
Fold & Flip Phones
I've turned on camera flash notification because it helps me determine my notification if it's a message, and now it doesn't even let me use the flash light when I need it on my Galaxy Zfold6 it used to work on my galaxy S23 Ultra, can you please tell me what to do and fix it please?... Maybe it's the new One UI 6.1.1?
It would say the following
"Can't turn on flashlight because the light is being used by Camera flash notification"
realaud
Honored Contributor
Fold & Flip Phones
Maybe switch to edge lighting instead of camera flash for notifications? If you need to distinguish your message notifications from other notifications, you can give it it's own sound.
user8UBvFwtnlV
Fold & Flip Phones
I'm having the same issue with my fold 6. Even when I turn off the flash notifications, the flash light still doesn't work and gives the "Can't turn on flashlight because the light is being used by Camera flash notification" message.
user8UBvFwtnlV
Fold & Flip Phones
Getting the same message. I downloaded a flashlight app from the app store and now it works just fine. I will use that until samsung figures it out.
Sum1blak
Fold & Flip Phones
Go to accessibility >Advanced Settings>Flash Notification.  Then toggle it off and back on. Flashlight will now work
Luzme
Cosmic Ray
Fold & Flip Phones
Why can't I use the flashlight if I have flash notification enabled? That didn't happen before.
LongHiker
Galactic Samsung Care Ambassador
Fold & Flip Phones
@Luzme Flash notification has nothing to do with enabling/disabling the Flashlight feature. Please provide more details on what you are trying to do.
GaryB82
Fold & Flip Phones
As @LongHiker said it should work and I can confirm the flashlight does work with Flash Notification turned on
If you've found my post to be helpful, Please like my Comments āœ“āœ“āœ“.
If my response resolved your issue, please press the Like and āœ“āœ“āœ“ to Accept as Solution button.
Luzme
Cosmic Ray
Fold & Flip Phones
I know it doesn't have anything that affects the flash notification but I get a message that says I can't use the flashlight and sometimes I can use it.
Luzme
Cosmic Ray
Fold & Flip Phones
The flashlight cannot be turned on because Camera Flash Notification is using the light.1723213915652.jpg
