Z Flip 6 Restarting problem
(Topic created: 08-15-2024 04:38 PM)
Pepsi57
Fold & Flip Phones
Randomly today my Z Flip 6 started restarting anytime I closed my phone. Tech support was unsuccessful and I dont want to waste my time at UBreak IFix to get my phone serviced if I don't have to.
Does anyone know how to fix this issues or is this something where I need to get a phone replacement for?
Any help is much appreciated!
Samsung_Moderator
Fold & Flip Phones
Hello, Welcome to the Community. We understand how frustrating it is for the phone to restart itself when closing it. There are some steps that may help.
The first recommendation is to clear the cache partition.
- Turn off phone
- Once off, hold down volume up and power buttons simultaneously
- When Samsung logo appears, release power button BUT KEEP HOLDING VOLUME UP until the recovery menu appears
- Use volume buttons to navigate down to clear cache (NOT CLEAR DATA/ FACTORY RESET)
- Use power button to select.
You can also try the troubleshooting steps here: https://www.samsung.com/ca/support/mobile-devices/galaxy-device-reboots-repeatedly/
If the phone continues to restart, it is recommended to have the phone evaluated at an authorized service center. You can use the following link to find a list of service centers near you that can do the repair: http://www.samsung.com/us/support/service/location or by contacting customer support at 1-800-726-7864.
For service outside the U.S., please use this link: https://www.samsung.com/us/common/visitlocationsite.html
For replacement options, you will need to check the exchange options with your retailer.
Will-i-am702
Comet
Fold & Flip Phones
Try deleting your cache sometimes it will help
Pepsi57
Fold & Flip Phones
Tried it and it didn't work☹️
Samsung_Moderator
Fold & Flip Phones
- Turn off phone
