- Mute
‎04-14-2019
06:46 PM
(Last edited
‎12-17-2023
03:40 PM
by
SamsungChelsea
) in
Is there anyway to check the battery percentage of the case? I know that you can check the battery of each bud in the galaxy wearables app but not the case itself. Also, is it just me or is the double/triple tap for track control a bit difficult sometimes to register?
Solved! Go to Solution.
- « Previous
- 1
- 2
- Next »
- Mute
‎01-20-2020 04:36 PM in
Galaxy BudsBattery power is moderate (between 30% and 60%)
- Mute
‎04-14-2019 06:58 PM in
Galaxy BudsI agree with you bro, it should say it, just like the airpods!!
- Mute
‎04-14-2019 07:26 PM in
Galaxy BudsYes it has been very flaky for me as well, the double taps work very rarely
- Mute
‎09-23-2019 04:46 AM in
Galaxy BudsDouble-taps and triple-taps have worked perfectly for me.
- « Previous
- 1
- 2
- Next »
