How to display Galaxy buds and case Battery levels?
(Topic created: 04-27-2020 11:34 PM)
KingOfRamen
Galaxy Buds
After i update my galaxy buds to the software R175XXU0ATD3, my left buds disconnected once in a while. And when i open the galaxy app to view, i only see one battery indicator for both buds. Im not sure did this happen only to me. Have anyone face this problem after updated the latest software R175XXU0ATD on your galaxy buds plus?
mkkim
Comet
Galaxy Buds
Hello@KingOfRamen
I just realized, when only one of the two earbuds is used, the battery indicator is shown separately. Try to using only one bud for 10min. then you can see the battery indicator is displayed separately.
ErwinR
Galaxy Buds
Concerning battery level, same here. it's very annoying.
MrZell
Black Hole
Galaxy Buds
Hey there!
Thank you for reaching out for assistance.
Have you already tried resetting the buds through the wearables application?
KingOfRamen
Galaxy Buds
Yes i did but still the same. I think maybe this is the latest software that samsung try to make it as one
@MrZell wrote:
Hey there!
ErwinR
Galaxy Buds
No difference after resetting the Buds. Also after reinstall of the applications (Wearable and Buds+) and reconnect the buds, the issue still exists. (Phone is S20).
@MrZell it must be something in the latest update.
userqNxXf4T1XM
Cosmic Ray
Galaxy Buds
Same issue here. Please fix it asap.
Resetting the earbuds, deleting and reinstalling the Galaxy wearbale app, deleting app cache nothing works. Its a software bug.
mkkim
Comet
Galaxy Buds
Hello@KingOfRamen
KingOfRamen
Galaxy Buds
Hi mkkim
great discover from you. I will try this and see mine. Do u think this is what samsung want for this new updated or it is a bug that need fix on their future updated?
@mkkim wrote:
Hello@KingOfRamen
