mike57746644
- Mute
- Email to a Friend
‎11-01-2020 06:28 AM in
Galaxy Note Phones
So I purchased this great $45 samsung 45w dual car charger for my note 10 plus. I get it delivered I can hardly wait to use it . I take it out of the box I am like wow this charger is great . Really nice and durable . I plug in one end of the supplied usb-c 5w cable into the car charger the other end into my note 10 + and phone says super fast charging.
Then unfortunately 2 minutes later stops charging . I unplug and put back in it will charge for 2 minutes then stops again. This car charger also has 15w input that works great and fast charges the phone, but I can not use the 45w input as it only charges for 2 min then stops
I think this is a software related problem. Is any one else having this issue .
I have Note 10+ AT&T and the Samsung 45w dual car charger.
Solved! Go to Solution.
mike57746644
- Mute
- Email to a Friend
‎11-02-2020 06:25 AM in
Galaxy Note Phones
I found solution
set phone display to always on while charging for some reason this will let phone super fast charge .
I believe it stops when the phone goes from aod to lockscreen by itself
if set screen to always be on while charging this is work around
this is indeed a software issue
hopefully someone is listening 🙂
AT&T Note 10 +
AT&T Note 10 +
Adaboy
Supernova
- Mute
- Email to a Friend
‎11-01-2020 09:15 AM in
Galaxy Note Phones
Maybe the vehicle charging systems is the culprit. Have you tried it in another vehicle?
mike57746644
- Mute
- Email to a Friend
Galaxy Note Phones
I found solution
AT&T Note 10 +
AT&T Note 10 +
