How do I use Gestures with the Galaxy Ring?
(Topic created: 07-19-2024 08:42 PM)
userY5X7GI4NtJ
Galaxy Ring
Just got my Samsung Ring this afternoon.
I have seen TikTok and Youtube videos showing that you can take pictures and videos by doing certain hand gestures. However, I can't seem to find that feature on my phone. Is it because the feature isn't available on the S23 Ultra yet?
ButtaBean_420
Black Hole
Galaxy Ring
Not available yet need to be running One UI 6 1.1 or higher probably won't be to long before the updates get pushed out
ButtaBean_420
Black Hole
Galaxy Ring
LTMets44
Galaxy Ring
I'm having the same issue. "Gestures" does not even show up in the menu. I called Samsung and was hung up on three times, and I've chatted with support and they were no help at all. So I came here and thanks to @ButtaBean_420, now I know I have to wait until the One UI 6 1.1 update. Thank you for validating that I'm not crazy.  You would think Samsung Support would know these things!!
Looknow12
Cosmic Ray
Galaxy Ring
Yes it's not in the wearable app as an option. Waiting for the One UI update.
