Battery Dying Faster
(Topic created: 3 weeks ago)
musicsmylife29
Cosmic Ray
Galaxy Ring
Anyone else having issues with their ring battery dying a lot faster? Mine seemed to last 4 to 5 days but within the last week it's lasted about half that. Frustrating.
LongHiker
Galactic Samsung Care Ambassador
Galaxy Ring
@musicsmylife29 My ring's battery is lasting a long time. I am using a watch which also helps make the ring's battery last longer.
musicsmylife29
Cosmic Ray
Galaxy Ring
I have mine set up with my watch too.
Robin621k
Honored Contributor
Galaxy Ring
I get 6 days on my ring, size 11.
Paired with my watch.
Try resetting the ring to see if it will improve.
sullins
Halo
Galaxy Ring
You may have had an update which could temporarily affect battery performance. The ring will eventually reoptimize the battery, which will fix battery life.
AceTrader
Galaxy Ring
My ring has been lasting up to a week until the last few days. Now it discharges from 100% to 0% in about 3 hours. Only fix suggested is mail in repair.
musicsmylife29
Cosmic Ray
Galaxy Ring
I reset it finally and now it seems to be working as it should be again.
