Missing data when Ring not close to phone/no Bluetooth connection. Do you have to keep your Ring close to your phone ALL THE TIME???
(Topic created: 01-18-2025 09:58 AM)
userPqh5vwJ95P
Cosmic Ray
Galaxy Ring
I wear my Ring to go to an exercise studio and take a high-intensity, circuit training 45 minute class, while leaving my phone in the locker about 100 ft away.
When the class is finished I come back to my phone to sync, but it seems that the Ring is not recording the activity at all and there is a 60 minute window of NOTHING in the heart rate/BPM logs!
The heart rate/BPM logs are empty during the time of my exercise class!  Almost as though I didn't even work out...!
I assume this is because my Ring could not communicate with the phone using Bluetooth as its too far away?
But shouldn't the Ring store this activity on the device itself and then sync/download when a Bluetooth connection is established again?
This has happened 3+ times now, ever since I got the Ring recently.  It has never worked correctly.
printaudio
Galaxy Ring
Can't listen from my airbud
userPqh5vwJ95P
Cosmic Ray
Galaxy Ring
This is unrelated to Ring.  You're in the wrong place.
userPqh5vwJ95P
Cosmic Ray
Galaxy Ring
Nobody has any comments?
So when you go for a 1 hour run and leave your phone at home.....does it save all that data to the Ring and sync up perfectly again (to record the heart rate BPM details, etc during the run) when in Bluetooth range of your phone again?
If so....I am NOT seeing that behavior.
Ceitel
Galaxy Ring
I have left a similar message on these forums with no true answers or support, mine is when I'm running, using stair climber, rowing, none capture heart rate automatically. I have to choose a random workout that does capture heart rate (such as indoor bicycle or treadmill) and even then the max heart rate can be displaying 1/2 what the machine says I'm at and I trust the machines as they all are in the same range during vigorous activity
userPqh5vwJ95P
Cosmic Ray
Galaxy Ring
It's frustrating that nobody from Samsung is reading or commenting on these posts...
