Ring not stable with connection
(Topic created: 01-20-2025 08:23 AM)
Galaxy Ring
My ring keeps disconnecting from my phone and i have to reset the ring please fix the connection issue on the ring another update hopefully
SamsungModerator1
Galaxy Ring
Thank you for reaching out. I can certainly understand your frustration with your Galaxy Ring repeatedly disconnecting. If your Galaxy Ring disconnects from your phone, then there may be an issue with the Bluetooth connection. You can fix this by reestablishing the connection, ensuring there are no obstacles, and updating the Galaxy Wearable app. Give this link a try for more steps to troubleshoot the disconnection between your ring and phone: https://www.samsung.com/us/support/troubleshoot/TSG10003289/
If you continue to experience these symptoms after completing the troubleshooting steps, I would recommend submitting an error report. This will allow our team of engineers to get a hands-on look at the symptoms you are experiencing: https://us.community.samsung.com/t5/Tips-Tricks/How-to-Send-Feedback/ba-p/3001692
DrewsNetwork
Galaxy Ring
I am having the same issue and looking for an update on a solution.
hallant81
Galaxy Ring
Same here. It's annoying.
userQQcYVE8Hds
Galaxy Ring
Me too. Fix this please
userlQ1mpzieii
Galaxy Ring
same, it constantly disconnects from bluetooth and the wearable app. UNREALIBLE.
SamsungModerator1
Galaxy Ring
