Ring not connecting anymore
(Topic created: 12-02-2024 04:42 AM)
Redsoxfan74
Cosmic Ray
Galaxy Ring
Has anyone had an issue with their ring connecting to the phone? Mine does not at all anymore. Just started happening on 12/1, and haven't been able to reconnect it since.
Redsoxfan74
Cosmic Ray
Galaxy Ring
I am all set now. I had to delete the ring from galaxy wear, and reinstall it. That worked. Delete it, then do the process like your connecting it for the first time again.
BlueSkies
Comet
Galaxy Ring
Can you check if there was a recent update applied? If so can you try resyncing the device?
Redsoxfan74
Cosmic Ray
Galaxy Ring
I do see alot of complaints on the wearable app in the store recently. I believe there may have been a recent update there? I have restarted my ring, restarted the Bluetooth. Maybe I will try to delete the ring and reconnect?
Members_hSQWDSE
Galaxy Ring
I'm having that problem.
Members_hSQWDSE
Galaxy Ring
My ring doesn't seem to stay connected.
Redsoxfan74
Cosmic Ray
Galaxy Ring
