Galaxy S9 battery drain and temperature issue
(Topic created: 03-03-2024 11:37 PM)
missg88
Galaxy S Phones
So I have the Galaxy S9 an my battery dies quick also the phone gets HOT what should I do? Or what can I do?
JUMP TO SOLUTION
Galaxy S Phones
Did you click on it
missg88
Galaxy S Phones
Yes I did. So do I just keep looking at that page tell the s9 is added? Or how would I know when it gets added?
Galaxy S Phones
To tell you the truth I'm actually not sure if they allow that type of followage what people usually probably do is just keep going on the website every few months to check or you can go on their YouTube channel or Reddit page They have a Reddit page too
missg88
Galaxy S Phones
Whats there YouTube channel
Galaxy S Phones
https://devices.ubuntu-touch.io/ click on the part where it says 24 supported devices
Galaxy S Phones
Oh yeah and the battery dies quick on the Samsung Galaxy S8 also One of the best Samsung phones was the S7
missg88
Galaxy S Phones
Will this is a bummer cause I honestly liked the S9
patriciostarr
Supernova
Galaxy S Phones
You could replace the battery but like a lot of people said, is better to get a new phone
Technotakusai
Cosmic Ray
Galaxy S Phones
You could get the battery replaced .
Here are some suggestions to extend the battery life of your device:
- Consider replacing the battery if necessary.
- Configure your device's battery settings to optimize charging. For example, limit the maximum charge level to 80% to reduce battery degradation.
- Manage background data usage by identifying and restricting apps that consume excessive data when not in active use.
RobXbalboa
Red Giant
Galaxy S Phones
Sounds like a rogue app. Or you have bad signal. (The cellular signal is number 1 priority and will burn a battery up fast searching especially in a walmart type metal roof building) I would back it up with Samsung smart switch and reset it. Then restore it through the back up.
