Wireless Charger Flashing Red Lights
(Topic created: 07-08-2023 07:30 AM)
xxXBgDXxx
Galaxy S Phones
I plug in my Samsung Duo Wireless Charger EP-P5400.
The lights turn on一Red-Green-Orange (the working pattern) for the right (watch and buds side), Continuous Red for the left (phone side).
The left phone side doesn't work any longer.
Any fixes?
Rydah
Planetary Samsung Care Ambassador
Galaxy S Phones
Hey there @xxXBgDXxx, I hope you're doing well.
Are you using the charging brick/power supply that came with the wireless charger? Have you tried another outlet? How long has this been happening?
Best regards,
Rydah
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
Rydah
Galaxy S Phones
Best regards,
Rydah
ChaosSaber
Honored Contributor
Galaxy S Phones
Them chargers don't come with a power brick
xxXBgDXxx
Galaxy S Phones
It began after our power went out that night. But it was plugged into a surge protector.
I use an Anker charger and cable with the wireless charger.
So I moved it to another Anker charger and cable that wasn't surge protected, and it "slowly came back to life."
The lights began to come on in the correct order but very slowly. And now, everything runs like normal.
Thanks!
xxXBgDXxx
Galaxy S Phones
No solution, it came back to life as time passed ha ha
