- Mute
‎10-23-2022 11:30 AM in
Galaxy S22I wear Phonak hearing aids which worked with my previous Pixel phone for phones calls, and music apps via Bluetooth. It also worked for the manufacturer provided hearing aid control app.
I needed to replace my Pixel phone and I bought a Samsung Galaxy S22. I paired my hearing aids with the phone and loaded the Phonak app which works via Bluetooth but no other apps work with the hearing aids as output devices, not even for phone calls.
Is there some setting which is not correct for this to work or is this considerably more expensive phone not capable of identifying and using my hearing aids as an output device?
My hearing aids are Phonak Audéo M90-R. The hearing aid manual says they should work with "Android" phones so I'm hoping it it just a setting which I cannot find that would enable the device to be listed and therefor selected for a two way communications device.
Any thoughts on what setting may need to be changed or enabled? See attached page from the Phonak manual indicating that it should work.
Solved! Go to Solution.
- « Previous
- 1
- 2
- Next »
- Mute
‎10-24-2022 01:09 PM in
Galaxy S22No problem. The update and the reply must have crossed in cyberspace. Thanks again.
I still don't get why the "Smart Things" app only configures the Right hearing aid even though the calls play through both.
Small concern, as long as long as it works I'm happy.
![](/skins/images/8DCF8DB6CCE101846D964DBE00829662/responsive_peak/images/icon_anonymous_message.png)
- « Previous
- 1
- 2
- Next »
