Bluetooth not working for calls and audio at the same time
(Topic created: 03-16-2023 08:52 PM)
CheyL
Galaxy S23
When I first got my phone everything was fine, but now when I connect my Bluetooth headphones, I can't hear any audio, I tried researching, doing the connect, reconnect, toggle settings, etc. But the only thing that works is I have to manually disconnect and select only audio, but then I can't use it for calls. And the moment I connect for calls, in the setting audio is on, but no audio sound comes out. Any advice?
CheyL
Galaxy S23
Yeaa when it happened to me, only once I was home and restarted it worked, I had to disconnect everything, make sure the Bluetooth was off then do it again. It's a pain when it randomly happens (it still happens every once in a while)
Robin621k
Honored Contributor
Galaxy S23
What kind of headphones do you have?
CheyL
Galaxy S23
I have airpods
Robin621k
Honored Contributor
Galaxy S23
You don't get this in Blue tooth pageScreenshot_20230317_000055_Settings_1000008269_1679025655.jpgScreenshot_20230317_003410_Settings_1000008270_1679027650.jpg
CheyL
Galaxy S23
Yes I get that on my Bluetooth page. I placed in my original post that whenever both are highlighted, there is no audio, it will only work after disconnecting and reconnecting and only selecting audio
Robin621k
Honored Contributor
Galaxy S23
Did you try resetting your Airpods?
Ps. Why have Airpods on a Samsung phone?
CheyL
Galaxy S23
Yes, I've tried that, I've also restarted my phone. I was out at the time and tried again while I was home and now it seems to be working. And because I already have airpods
CareyAnn
Galaxy S23
Mine is doing the same thing
CareyAnn
Galaxy S23
I have Beat headphones
Robin621k
Honored Contributor
Galaxy S23
Do you have the Beats app on your phone?
