Galaxy s24 ultra battery drain
(Topic created: yesterday)
Deezi
Cosmic Ray
Galaxy S24
I don't know if it has something to do with the last couple updates but I have noticed my battery has been draining a lot faster it used to last all day wouldn't have to charge it but every two days now by lunch time it's down to 60%. is there an app that can help battery drain or is there a software fixed?
Galaxy S24
How do you charge your phone super or normal
Galaxy S24
Well now its just called fast
jt13890
Cosmic Ray
Galaxy S24
Check apps that are using yo I r battery the most. It is possible you have malware, or your phones battery is aging
