- Mute
ā03-18-2024 02:47 PM in
Galaxy S24Hello,
I recently upgraded to an S24 Plus, and have been having issues with android auto/Bluetooth in my car. I have 2 cars- in the one car, media plays just fine, but when I try to use the Google Assistant ("OK google"), there is no audio from the Google assistant. I can see captions on my phone of what the assistant is saying, but no audio. Again, media audio works fine.
On my other car, which has android auto, I can connect without an issue, and I see the android auto interface on the infotainment system, but there is no audio at all, no media etc, even though the title/artist/album etc still shows up on the screen. When I try to connect to the car's regular bluetooth audio, it seems to allow the audio for a few seconds, then it turns off, again the title/artis/album still show up, just without audio.
Any help with this issue would be greatly appreciated
- Mute
ā03-18-2024 05:08 PM in
Galaxy S24- Mark as New
- Mute
ā03-22-2024 08:52 AM in
Galaxy S24Sorry it looks like my previous reply didn't post.
The car with Android auto is a Porsche 981 with the stock PCM3.1 head unit, and an aftermarket zz2 android auto module. The phone connects to it just fine, with the android auto interface showing up, just no audio. I've tried everything I can think of including deleting and reinstalling android auto, resetting bluetooth and wifi settings, resetting all phone settings, system update, reinstalling spotify and Google maps
The other car is a toyota corolla. It does not have android auto, just regular Bluetooth. Media will play via Bluetooth, but I can't hear any voice prompts from the Google assistant
- Mute
ā03-21-2024 02:23 PM in
- Mute
ā03-21-2024 07:18 PM in
Galaxy S24Make sure the phone is paired to the car for calls and audio/music, not just as a handsfree device. Someone else had that issue. I'd delete the pairing from the car and the phone, reboot and start over.
- Mute
ā03-22-2024 08:53 AM in
Galaxy S24I've tried doing that.
Also my android auto module connects to the phone via wifi actually. It has the ability to plug in a wired USB connection as well, which has the same outcome- android auto interface works but no audio
- Mute
ā03-22-2024 01:28 PM in
Galaxy S24Is the phone connected to anything via Bluetooth, while it's connected to the android auto module?
- Mute
ā03-22-2024 01:31 PM in
Galaxy S24I've tried disconnecting it from any other bluetooth devices to see if that helps, but to no avail. It seems that my phone Will pair to the actual aftermarket unit via Bluetooth, but then it creates it's own wifi network through which android auto is transmitted
- Mute
ā03-22-2024 02:15 PM in
Galaxy S24So is it connected via both Bluetooth and WiFi to that module simultaneously? Or just WiFi? Seems like a weird setup for android auto.
- Mute
ā03-22-2024 06:58 PM (Last edited ā03-22-2024 06:59 PM ) in
Galaxy S24It seems to be both. And honestly I'm still trying to figure this all out myself as well.
It's called a ZZ2 module, and the way it pairs with a new phone is with an initial wired usb connection, then it's wireless after that. When it first boots up it goes to a proprietary home screen, and then android auto is an app within it. It seems the phone initially bluetooth pairs to the ZZ2 device, then once android auto is initialized the phone connects to a wifi network produced by the module. Shutting off either Bluetooth or wifi on the phone causes android auto to shut down
![](/skins/images/4842330E96EDF2B66EA8F5D1E6119091/responsive_peak/images/icon_anonymous_message.png)
