Adjust battery charge indicator contrast.
(Topic created: 02-04-2025 07:29 AM)
Tom6068
Black Hole
Galaxy S25
Hey All,
Is there a means to change the battery charging indicator in the notification areas to be opposite contrast. It is very difficult for me to see the indictor with black numbers on a white background.
JUMP TO SOLUTION
MrGhoul
Red Giant
Galaxy S25
The new battery icon was a terrible choice.
CoolZilla
Galaxy S25
I agree!
_userSAMGLXY_
Cosmic Ray
Galaxy S25
It was great before the recent beta update.
Dipak2002
Galaxy S25
The new battery icon sucks big time.  Needs to be changed immediately.
userfmDqINvKlD
Cosmic Ray
Galaxy S25
I agree. The battery percentage is very difficult to read. I would rather have the option back to have the percentage next to the graphic. There is not enough contrast to read the tiny numbers against the gray background.
Steven68
Galaxy S25
Yes, the new style battery life indicator is way too small. The main problem is that it shows a level using a gauge style in addition to the percentage value. It's the gauge level that makes it tough to read depending on your wallpaper. I believe if it just had a percentage value, it would be fine.
tetek
Galaxy S25
I totally agree! Need magnifying glass to see the charge. Please fix it.
Hexamer
Cosmic Ray
Galaxy S25
Yes. Fix it Samsung.
Jasons25
Galaxy S25
+1 its too small. Just let me put numbers instead of putting it in a dang pill looking icon...
FallBack76
Galaxy S25
It's impossible to see. I had no problem with s24 ultra
