Adjust battery charge indicator contrast.
(Topic created: 02-04-2025 07:29 AM)
Tom6068
Black Hole
Galaxy S25
Hey All,
Is there a means to change the battery charging indicator in the notification areas to be opposite contrast. It is very difficult for me to see the indictor with black numbers on a white background.
JUMP TO SOLUTION
kennethb
Galaxy S25
The battery percentage indicator on my S25 ultra is too small
Junyer357
Galaxy S25
I agree on my s25. The new style is also very hard to read when the bar drips down into splitting the numbers as well. I liked the old format better.
realaud
Honored Contributor
Galaxy S25
You can add a battery widget to your home screen or your lock screen. The battery status indicator has always been small, there's only so much real estate on the status bar.
MsVirgo87
Supernova
Galaxy S25
I told samsung this already and they say ( air quotes) that they are going to look into it and do something about that
realaud
Honored Contributor
Galaxy S25
Maybe they will and maybe they will leave it as it is.  In any case, it would be a project for a future update. In the meantime, just add a battery widget to your screen.  You can also create a routine to tell you to charge your phone when it reaches a certain percent, so you don't even have to look at the battery indicator.  I have my routine set to remind me at 30%.
MsVirgo87
Supernova
Galaxy S25
You're right and I'm good with how it looks for now, I got used to it alil bit
user0vnQJDJw5r
Galaxy S25
The older style is definitely much easier to read. I hope Samsung redesign the one UI7 battery level indicator to something more legible.
userfmDqINvKlD
Cosmic Ray
Galaxy S25
I cannot glance at the new icon and read the percentage, especially if the contract split on the background is within the percentage numbers. At the very least, give customers an option to separate the numbers and graphic again.
Pradeep_RK_India
Galaxy S25
The battery indicator in S25 ultra is almost unable to read, the battery indicator is a primary factor for an user and adding widget is not a good decision, surely we nead the update. Even in the lower end phones we have the option to customize the battery indicator, finally it's a foolish decision by samsung.
userxlNlcpGBg5
Galaxy S25
The battery percentage icon in status bar is too small to read!! The area showing battery power is Grey making it hard to see the white text of the percentage number. The icon doesn't need to be bigger, just INCREASE the contrast between text and background. Make percentage BIGGER. Or just have the option to have percentage WITHOUT a background like on the S24. Otherwise a GREAT phone. Love it.
