Adjust battery charge indicator contrast.
(Topic created: 02-04-2025 07:29 AM)
Tom6068
Black Hole
Galaxy S25
Hey All,
Is there a means to change the battery charging indicator in the notification areas to be opposite contrast. It is very difficult for me to see the indictor with black numbers on a white background.
Robin621k
Honored Contributor
Galaxy S25
In the support tab in this app. Scroll down to Send Feedback
Faith7777
Comet
Galaxy S25
I agree, though I love the new little icon, I've had to add a battery icon to my widgets because I'm unable to see it. Maybe, even possibly do the black numbers Bold or white numbers with a black inside with a white circle around it.🤔
LongHiker
Galactic Samsung Care Ambassador
Galaxy S25
Not sure if there is a way to change it. Another option is to add a battery widget to your home screen.
To do that:
1. Long press on a blank spot on the home screen
2. Cleck the widgets icon
3. Click on the battery list and select one which works for you.
Tom6068
Black Hole
Galaxy S25
Thnx, but I don't want to add a widget. It would be superfluous to one that natively provides that function. The clock on the left side is how the view should appear. I'm glad that the indicator range wasn't made like battery indicator.
In the end, it's not a big deal. I'm older, my right eye went through cancer treatment therapy which distorted my vision. But I'm getting prescription reading glasses that will only be needed for its specific purpose. I'm sure it will be easily seen then.
Perhaps you could suggest that for a future update as a choice?
usereAZcchmSGe
Galaxy S25
Agreed, please fix icon no need for a widget
Robin621k
Honored Contributor
Galaxy S25
When I was in Beta I reported it all the time! It's awful!
Einer321
Galaxy S25
I can not see the battery life on this phone
JRMartinez
Comet
Galaxy S25
On device care
ChessM
Cosmic Ray
Galaxy S25
It looks like with the new UI that Samsung has stacked the battery bar on top of the battery percentage.  This makes the battery percentage harder to read as the darker bar moving from right to left covers the digits.
Has any one found a way7 to just show percentage number and not have the bar cross the numbers?
meself
Honored Contributor
Galaxy S25
Not seen anyway of changing it
