Adjust battery charge indicator contrast.
(Topic created: a month ago)
Tom6068
Supernova
Galaxy S25
Hey All,
Is there a means to change the battery charging indicator in the notification areas to be opposite contrast. It is very difficult for me to see the indictor with black numbers on a white background.
JUMP TO SOLUTION
lizzy64
Cosmic Ray
Galaxy S25
I agree, it is difficult to see. I don't bother looking at it . I installed one of the battery widgets and use that instead. I do miss being able to glance at it though. Hopefully they will do something to improve its visibility.1740926246150.jpg
Please_help_me
Galaxy S25
Thank you for letting me know what u did! Very much appreciated.. I'll look into that.
Samsung can u fix this issue so we don't have to look for a workar9?
Chrysi
Galaxy S25
I am not happy with the Samsung Galaxy S25 Ultra 1TB phone.
After so much advertising, I expected something different and not a change of symbols. For example, the battery percentage is hard to read. The percentage is inside the battery. It should be moved to the left or right of the battery. The changes should be correct and not to justify that something has changed. I hope this error yo be corrected because there is no way to recover with the existing phone settings. The battery life is short for many applications. It should be more than 5000. etc. The new phone is very expensive for the services it offers. I'll think about it if I buy Samsung again.
