There is a problem with the sensors - body composition
(Topic created: 01-21-2025 11:41 AM)
Ferret_monkey
Galaxy Watch
Hi there, I recently purchased the Galaxy Watch6 Classic and despite the fact that the silver looks cheap and ugly, I'm mostly happy with the watch, although a few days ago it started producing an error when I try to measure my body composition.
The second I put my two nominated fingers on the buttons/sensors it immediately says 'there is a problem with the sensors. Contact customer support.
The watch has no problem measuring anything else, it's just the body composition feature which worked just fine until a few days ago.
To be clear, the rear of the watch is clean and unobstructed. The contact with my wrist is perfect and my fingers have no oil or other substances that should negatively impact on their contact with the button/sensors.  I do not have a fake tan or anything else to consider. I have the latest software update... Which might be related to this issue as it updated around the same time that the error first appeared.
Assistant would be greatly appreciated.
Thanks
Tabark
Galaxy Watch
Did anyone find a way to fix this issue ? I have the same problem 😕
Ianmac685
Galaxy Watch
I am having the same issues yet my son has the same watch but the smaller 40mm version and his still works.
Ianmac685
Galaxy Watch
I have just been online with Samsung support chat and have been given some advice which I will attach, also the more people that report the issue it then becomes a common issue which pushes through software fixes
userNuFVKsnlTY
Galaxy Watch
I just did the report.  Thanks for sharing this... just checking is any response from support?
Scottla94
Galaxy Watch
Just got the new update body composition still doesn't work all other sensors still fine
SleepDeprived
Galaxy Watch
the same for me ☹️
Clemito
Galaxy Watch
I'm having the same issue on my Galaxy Watch 6. If anyone has found a solution or got a response from Samsung, I'd really appreciate it!
tonovcp
Galaxy Watch
Same here, only sensor that doesn't work.
Bbevalina
Galaxy Watch
I've got same issue. Not been able to resolve and not really any support unless you book a repair.  Which is always at a cost when its actually a product fault......
userisOjYODWWD
Galaxy Watch
Still not working after one UI 8 update...
