- Mute
02-20-2017 08:33 AM (Last edited 08-01-2017 01:35 PM by SamsungViv ) in
Gear and Gear FitI am using a Samsung Gear S3 Frontier and a Nexus 6P phone. I can't seem to see how to change the weather data from Celius to Farenheit. Can someone please let me know how to do this? Thanks!
Solved! Go to Solution.
- Mute
02-07-2019 03:27 PM in
Gear and Gear Fit- Mark as New
- Mute
08-19-2017 08:48 AM in
Gear and Gear FitHave same phone and watch and same problem, thanks for the help.
- Mute
11-21-2017 06:54 AM in
Gear and Gear FitHi,
I use lenovo zuk z2 plus.
I am not able to change unit in mobile application at below path. When I tap Unit it show F and C but I am not able to select C.
Gear Manager App>Settings>Apps>Next to Weather there will be a Settings icon(gear)>Unit
- Mute
11-22-2017 07:49 AM in
Gear and Gear FitWhat language is your phone set to? that could change if this option is available.
- Mute
04-01-2018 06:21 AM in
Gear and Gear FitVery helpful, thank you.
- Mute
04-28-2018 10:20 PM in
Gear and Gear Fit
@SamsungVivwrote:Alrighty. I dug about a bit, and by that I mean I borrowed a friend's Gear S3 and talked to them about theirs. After shifting about, because their widget was showing both Celsius AND Fahrenheit, I think we found the answer! Try looking at your phone, Gear Manager App>Settings>Apps>Next to Weather there will be a Settings icon(gear)>Unit. That 'Unit' can be changed from C to F. 🙂
This worked for me, Thanks!
- Mute
06-02-2018 06:17 PM in
Gear and Gear FitThank you very much!!!!! I had the same Q and you solved this for me as well!!!
- Mute
06-19-2018 12:11 AM in
Gear and Gear FitGreat, Thank you, this worked for me
- Mute
07-07-2018 03:33 PM in
- Mute
07-27-2018 05:19 AM in
Gear and Gear FitOmg thank you so much. i just got the Samsung sport for Mother's day this year and it was driving me cray cray.
