QN90B TV And Wifi Surround (Rear) Speaker Without Using Any Soundbar
(Topic created: 11-25-2022 01:53 AM)
ergunyucel
Home Theater
Hello,
I have a 75" QN90B tv and it has an option like this:
So I want to use a wifi speaker set (without soundbar). Is there any speaker kit? Or should I have to use it with soundbar? For example can SWA-9500s be connected to TV directly without soundbar?
STRATA
Galaxy
Home Theater
Hey ergunyucel
The QN90 Series are capable with most WIFI Audio casting for sound however it is up to your speaker system if it supports WIFI or not.
EXAMPLE: Let's say I'm using a QN90 Series TV, and I have a LG or BOSE Sound System that's has both WIFI & Bluetooth, I can have the Audio synced to the WIFI Speakers as long as it is on the same network.
Let me know it that helps answer your question.
1 Reply
STRATA
Galaxy
Home Theater
Hey ergunyucel
