- Mute
06-23-2020 02:43 PM in
Home TheaterThis is a great system but this morning i woke up to it not working at all,no sound,no Bluetooth connection,Connecticut, CD drive wont open and the display screen says "phase". How can i get this fixed
Solved! Go to Solution.
- Mute
09:11 AM
(Last edited
10-27-2021
05:22 PM
by
SamsungStephani
I'm sorry to hear that, If after unplugging and replugging the system up and it still does not work this will require service. This is out of warranty and will require the unit to be sent in for repair. I would recommend contacting our depot center at 310-669-4334 to get the service set up.
- Mute
09:11 AM
(Last edited
10-27-2021
05:22 PM
by
SamsungStephani
- Mute
09-26-2020 05:21 AM in
Home TheaterDid you get your stereo system fixed?
- Mute
10-28-2020 09:15 AM in
Home Theater- Mark as New
- Mute
11-27-2020 05:23 AM in
- Mute
12-26-2020 06:24 PM in
Home TheaterI need help I have the same issue can I send in for repair?
- Mute
12-10-2021 10:05 AM in
Home TheaterI need help with my system, experiencing the same isuues
- Mute
03-23-2022 01:31 PM in
- Mute
07-16-2022 10:42 AM in
Home Theater
