Wall mount parts for a sound bar
(Topic created: 11-17-2023 01:58 PM)
williejust
Home Theater
Samsung_Moderator
Home Theater
Hello! Thank you for reaching out! I would recommend going to samsungparts.com and enter your model number.
williejust
Home Theater
I need these parts...anyone knows where I can find them?
Dan2023
Honored Contributor
Home Theater
Have you contacted Samsung Support via the Support tab in this app?
Samsung_Moderator
Home Theater
williejust
Home Theater
I need these wall mount parts for this sound bar
