cporterfield
- Mute
4 hours ago in
Kitchen and Family HubNeed to know why the water filter is so hard to replace. It should be a simple task but it's difficult to turn the filter to the unlock position. HELP
realaud
Honored Contributor
- Mute
3 hours ago in
Kitchen and Family HubI always use a slip joint pliers to turn the filter--both in and out. They do not leave enough of a hand grip to turn it properly. Grab, push & turn, works like a charm and no grief.
realaud
Honored Contributor
- Mute
an hour ago in
FWIW, the filter is hard to place and remove because of the pressure seal.
![](/skins/images/AEB2FF4521FCCC815534148321FC33FB/responsive_peak/images/icon_anonymous_message.png)
