RPKB
- Mute
Friday in
Kitchen and Family HubHi! My refrigerator, model RS22T5201SR/AA, will not reset the filter indicator light. Specifically, the button that controls the ice maker / filter appears to be non-functional.
What I have done:
- made sure the controls are 'unlocked' using the lock/wifi button. (This button works)
- I can control the ice-maker through the app, so that function works; however the button doesn't work to control the icemaker or filter indicator.
- I have cycled power to the refrigerator. (More than once)
Is there anything else to try?
Thanks!
None of these
LongHiker
Legendary Samsung Care Ambassador
- Mute
Friday in
Kitchen and Family Hub@RPKB According to the manual you would need to "press and hold Filter Reset for 3 seconds." Have you already tried that?
https://www.samsung.com/us/support/downloads/?model=N0053896&modelCode=RS22T5201SR/AA
RPKB
- Mute
Monday in
Kitchen and Family HubYes, I have held the button for 3 seconds, multiple times.
![](/skins/images/52DAA9D2A1C3C5D9E9667C5EB8E11904/responsive_peak/images/icon_anonymous_message.png)
