Flex Door Frame is Broken
(Topic created: 04-11-2023 09:01 PM)
user3Ev8FZFnkL
Kitchen and Family Hub
I have a flex 4 door fridge and the frame of one of door is broken. I can’t find the replacement part and it’s instructions to replace.
looking for advice
Samsung_Moderator
Hi there! Thanks so much for reaching out about this. I can certainly understand the concern here. If it is the actual door piece that is damaged, you can find replacement parts on SamsungParts.com or by calling 1-800-627-4368. Additionally, you can find instructions on how to remove and reattach the door in the user manual for your model. All our manuals can be found on Samsung.com by searching the model number.
However, if the damage is to the refrigerator frame where the door is located, then this will require service. The following link can help you locate a service center in your area to further assist with this.
https://www.samsung.com/us/support/service/locations/
Diaboyos
Honored Contributor
Samsung support 1-800-726-7864
Samsung text support text START to the same number.
Samsung_Moderator
