Nx60t8511ss show TeSt mode and doesn't heat more than 175f
(Topic created: 08-14-2021 12:23 PM)
userLRVIkTVC1D
Kitchen and Family Hub
Couldn't find solution on user or installation manual.
SamsungAl
This means that the range is in demo mode. You can find the instructions on how to turn it off on page 31 of the User Manual 🙂
1 Reply
SamsungAl
