RS27T5200ST/AA: Inside the freezer, temperature is at -10
(Topic created: Thursday)
kmgblackwell
Kitchen and Family Hub
I have a thermometer in my freezer and it reads -10. I had to have my ice maker & sensor replaced because it cracked ice maker molds, leaking water into the bucket and in the ice dispenser. The control panel in the fridge reading freezer is at 5. I have reset the inside control panel and the fridge was unplugged for a bit when the ice maker was replaced.
I can't get the control panel to go any higher than 5 BUT I did see at 11 when I went to go turn on the ice maker (after the fix). Just FYI...before the fix, I turned off the ice maker but it would turn it self on, several times & I did lock it every time after I turned it off.  I had to rubber band the ice maker arm up just in case it decided to turn it self on, I had the ice bucket out of the freezer.
Question, do I need to replace the control panel that is INSIDE my fridge or the one that is on the OUTSIDE?
Thanks!!
LongHiker
Galactic Samsung Care Ambassador
Are your temperature readings in Celsius or Fahrenheit?
kmgblackwell
Fahrenheit
