Refrigerator RF25HMEDBSR water dispenser issue
(Topic created: 12-10-2024 08:28 AM)
userYCXuEZP3r6
Kitchen and Family Hub
Water dispensed fine last night but now nothing. What could be wrong?
Samsung_Moderator
Hello @userYCXuEZP3r6! Thank you for reaching out! I would recommend trying the information in the following link: https://www.samsung.com/us/support/troubleshooting/TSG01001875/. If this does not help then this will be something that will require service. Depending on your warranty you will have a few options.
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can Private message me or one of our moderators or you can call in directly at 1-800- 726-7864 with your full model and serial number to have service setup
- If you're OUT of warranty, you can use this link below to find a service center in your area.
https://www.samsung.com/us/support/service/locations/
Hotfairy871
Cosmic Ray
Change your water filter. Look it up on Amazon. Order a new water filter.
Samsung_Moderator
