What residue on the water dispenser shell
(Topic created: 04-21-2024 05:13 AM)
SamRame
Kitchen and Family Hub
Hello All,
I own a Samsung flex 28.1 refrigerator was cleaning the water dispenser area using goof-off (which is a mistake) and now I am left with white markings, which is very ugly.
How to remove these white marks? If that is not possible, I would like to buy the part (not such such part exist). Please see the picture.
Samsung_Moderator
Hello! Thank you for reaching out! You can try our parts' website samsungparts.com. You can also call them at 1- 800-627-4368, if the part is not available there service would be the only other solution. You can use the link below to find a service center in your area.
https://www.samsung.com/us/support/service/locations/
1 Reply
Samsung_Moderator
