Refrigerator family hub touchscreen unresponsive/display doesn't work
(Topic created: 11-20-2018 05:45 PM)
userop64rKJLlo
Kitchen and Family Hub
My family hub touchscreen does not respond to touch since yesterday , I can’t unlock the screen. I turned off the screen and turned it back but I can’t unlock the screen. I unplugged the fridge and it didn’t work either.
JUMP TO SOLUTION
user9fdb1T3jOI
I have tried all of the suggestions in this thread and none of them work for me.  Any other suggestions?
userN0IyV8VioI
Mine is doing the same thing. I've noticed once there is an update it usually resets and things start working correctly again. Hopefully there is an update soon. I love the idea of this refrigerator. It's upsetting with the  issues I've encountered. Besides this my ice machine has never worked correctly. I'm always constantly having to thaw it out myself because the function doesn't work. So, after several months I just bought a count ice machine and turned the function off. Hopefully the touchscreen will start working properly soon. I enjoyed this function as well ...
useraO1zzFmdYD
Mine is doing the same and it also happened around the software update. Mine also will not go to sleep anymore so I have turned off the red power button for the family hub.
userofYonza1qE
This worked the first time. Then it went again a few months later and now I'm out of warrenty
usersNMNP0ww9R
I have the same problem - the screen is stuck at the fanmily hub photos and wont respond to touch - I've reset with the red switch on the top of the door and nothing -  still works from phone app - help?
uservOf7KTYLLL
mine is doing the same. did you ever find out the problem,?
LinkUltra
I woke up this morning with an update on my screen and now it has become unresponsive. I've tried unplugging and switching the screen off,  nothing.
Not applicable
@userwMkiX05G9b    We are sorry to hear about this. Please send the model and serial numbers to this PM Link, and we will look in to this.
user3anbmt9LsQ
I am having the same problem. I awoke to find an update notification on my hub. The update screen is frozen and I cannot select any options on the screen. I have attempted to cycle the power with the red button and I have also tried unplugging the refrigerator. It seems the new update has caused this to happen to many units! My refrigerator is less than a year old! Ridiculous
user3anbmt9LsQ
Has anyone obtained a reasonable response to this problem?
