Refrigerator family hub touchscreen unresponsive/display doesn't work
(Topic created: 11-20-2018 05:45 PM)
userop64rKJLlo
Kitchen and Family Hub
My family hub touchscreen does not respond to touch since yesterday , I can’t unlock the screen. I turned off the screen and turned it back but I can’t unlock the screen. I unplugged the fridge and it didn’t work either.
JUMP TO SOLUTION
userTBwbcgKAYp
 we have the same issue - it started 2 days ago with the update- I can't locate a way to unfreeze the screen-  I know this doesnt help you
Hal
userTHLXXtUo7A
same issue! Samsung authorized tech is charging 200 bucks just to come look plus P&L. This is complete BS.
userwLv4AgCh0Y
I can't even get one to come out here.
userR1QchXqcXs
Was there a resolution to this?  Mine is doing the same thing.
user4vERGr1Nyj
Same here I have bought many Samsung products in the past, but this is ridiculous.
usertX3NoZt7Hh
Mine an RF28HMEDBSR was triggered coming back on from a power outage. I don't appear to have a red switch on either door or any other openable compartment to hide a switch in. Is there an off switch for this model? The screen keeps blinking but the touchscreen is unresponsive. No error codes just the temp blinking and blinking..?
userofYonza1qE
This is not an adequate solution and given the amount of issues, this looks like Samsung family hub fridges have defective manufacturing.
useruyHyvPtptE
This is bad for business
Have had this frigerator for 16 months
and nothing but problems
First the fan went out then the touch screen on the frig.
How can I fix the touch screen
Not applicable
@useruyHyvPtptE    We are sorry to hear about this. Please send the full model and serial numbers to this PM Link.
flowerchld
None of these solutions worked for me. Here  is what DID. I turned off the screen (the red button above the door.) I then unplugged the fridge for 5 minutes.  Plugged the fridge back in and then turned on the screen with the button above the door.  This seemed to reboot the tablet in a way that either unplugging or turning off the screen alone did not. Hope this helps someone else!
