Should I turn off the Ice maker when going on vacation?
(Topic created: 06-17-2023 05:49 AM)
user37J6BA4z4M
Kitchen and Family Hub
Should we turn off the ice maker when we go on vacation?   Thank you
Dan2023
Honored Contributor
Yes, and remove the ice tray as well.
Frost can accumulate, especially when ice is left to solidify in the tray, making it difficult, if not impossible, to remove the tray or extract ice.
Removing the ice tray will not affect the effectiveness or coolness of the refrigerator.
Please consult your frig's user manual for details.
Dan2023
Honored Contributor
notforhire
Honored Contributor
another trick: take an old-school ice tray, fill it up and let it freeze. when you leave, turn it over in the freezer.
if, while you're gone your house loses electricity and it's off long enough, the ice will melt enough to fall out. if that happens, you know that your frozen meats will have also thawed and re-frozen, making them something you probably don't want to eat.
