- Mute
2 weeks ago in
Kitchen and Family HubI have a Samsung front loader washer. It runs perfectly, when there are no clothes in the washer. As soon as clothes are added, it does not matter how many, it will either not run, or runs to a certain point, leaving them in water. Every blue moon, it will run a whole cycle with limited clothing inside. This is rare. I have already checked all hoses, drainage, and cleaned the filter thing, at the bottom, to make sure there was no blockage. I cannot find a solution for this issue, on the net. Some people have had it, but there has been no one fix. The ones I do find, people have called in techs and the tech doesnt know, or they start replace everything thing. I am not going to go through replacing everything, because a tech cannot figure it out. I can replace the part myself, if pointed in the right direction. I am not opposed to calling a tech, but good ones are hard to find. Has anyone had this issue, and solved it? The washer is not overloaded. There is no blockage, anywhere, so please do not tell me to check it, as it has been done. It has also been recalibrated. We are at a loss. Thank you to all who answer.
- Mute
2 weeks ago (Last edited 2 weeks ago ) in
