Every button on my remote turns my TV off.
(Topic created: 04-18-2024 11:03 AM)
Wolfeboro
LED and OLED TVs
Model NO.: UN40H5003AF
This just started happening today, but every button on my remote now controls the power (except for the Power Button, strangely).  I press the Source button, power turns on.  I press Volume Down, power turns off.  I press Mute, power back on, you get the idea.  Whenever the TV turns off, the red light on the TV next to the Power/Menu button blinks rapidly before stabilizing and then the power is off.  I've tried draining the power from the TV several times, and I don't know how the issue started.  What's going on and how do I fix it?
ehsankarimi
LED and OLED TVs
Remove the remote's batteries and press each button to check for stickiness. Reset the remote by holding the power button for 20 seconds without batteries. Use your smartphone camera to check the remote's IR emitter. Power cycle the TV by unplugging it, holding the power button for 30 seconds, then plugging it back in. Check for any nearby devices causing interference. If necessary, try a factory reset using the TV’s physical buttons. If these don’t resolve the issue, contacting Samsung support or a technician might be your next step. Hope this helps!
Members_uq4mZYs
LED and OLED TVs
on the CU 7000 mine was doing the same thing this morning I'd use the buttons on my TV and go in and reset it and it fixed the problem this morning
Wolfeboro
LED and OLED TVs
Tell me more about that process
ehsankarimi
LED and OLED TVs
Wolfeboro
LED and OLED TVs
Well, I did most of that, not necessarily in that order, before your reply. And it didn't work at first, but now everything's working fine, so thank you
