Factory Reset has frozen TV at step 3
(Topic created: 10-23-2024 06:28 PM)
MRP1
LED and OLED TVs
My 50 inch Samsung smart TV had a memory overage notification and suggested I do a reset.  I started doing that and was directed to screen to do a reset.  I went through step one and entered the 0000 pin, and went to step 2, after step 2 went to step 3 hit the right arrow to advance and now the TV is frozen on step 3.   The remote buttons will no longer bring up any of the menus, nor allow me to to advance or go back (the only buttons that will do anything in this frozen state are the power and volume buttons)
I went through Samsung test support via text and that was absolutely worthless, all they would say is I could pay for someone to come out and maybe fix it, I was also told that I should buy another remote and believe it or not buy another TV.   I followed the directions that the smart TV directed and now Im stuck with a TV with a frozen screen on step 3 of the reset process and Samsung tech support doesn't have a clue on how to break out of/ reset the TV.   I will also add the TV and remote were working fine until I recieved the memory issue and advised to reset the TV.
Samsung_Moderator
LED and OLED TVs
Hey, MRP1
Thank you for posting within the community! We have a similar thread that already has an accepted solution. You can find that thread here:
<https://us.community.samsung.com/t5/LED-and-OLED-TVs/Stuck-on-Step-3/td-p/3006031>
We appreciate you being part of the community and look forward to future posts
meself
Honored Contributor
LED and OLED TVs
All I can find is press the power on the remote and kept pressed until tv restarts and also unplug tv for 5 minutes
Samsung_Moderator
LED and OLED TVs
Hey, MRP1
userooa9xMezMB
LED and OLED TVs
