Google browser on smart tv
(Topic created: 01-18-2025 05:23 AM)
Dmar1948
LED and OLED TVs
I have a 40 Samsung Smart TV purchased 2014. And 75 inch purchased 2017. The GOOGLE browser no longer works because it doesn't enable JAVA SCRIPTS. Updating to factory version hasn't fixed the problem
Samsung_Moderator
LED and OLED TVs
Hello! @Dmar1948 Thank you for posting about this. Check your tv for software updates. Confirm both TV's are running the latest firmware. Go to settings> Support> Software update> Update now. Older Samsung models may no longer receive browser updates due to hardware limitations.
Please let me know if this helps
Samsung_Moderator
LED and OLED TVs
Dmar1948
LED and OLED TVs
Thanks for the reply. I checked the Update now option and it replied that my Software had no updates. I wasn't thinking when I purchased 2 SAMSUNG SMART TVs TU I should have checked how long the browser is supported. Just like I would if I bought a computer or laptopp
